Sky+ = very poor audio
LDJ
Established Member
I’ve just had Sky+ installed this weekend and so far so good. Except for one fact, the audio quality is pretty bad!
I’m using the same cables as my previous digibox, which includes a good quality THOR scart cable, but the audio is quite muffled and ‘noisy’ almost a dull crackling sound in the background. Previously the audio output was fine on normal sky, but for some reason on sky+ the sound output is massively inferior
What could possibly be causing this?
Starburst
If this is happening on the audio via the scart, optical, phonos and the RF then it's probably a faulty box.
LDJ
Established Member
i hope not!
its definitely the same on both scart sockets. will have to try one of the other outputs and see.
LDJ
Established Member
I still have this problem...its happening from all outputs on the Sky+ :(
Starburst
Reckon it's safe to say it's the SKY+ itself then and not the TV or amp you are using.
Use the warranty and make sure they replace it with a brand new box and get some credit for the loss of viewing over the last week. After all the poor audio has ruined the viewing experience.
Klipsch The Sevens Powered Speaker Review Coming Soon
Back
