Sky+ V2 box static/vibration
Discussion in 'Sky Digital TV Forum' started by Begbie2003, May 13, 2003.
  1. Begbie2003
    Begbie2003
    I've just had Sky+ installed, I’m very happy with the picture and features.
    The problem is the box gives minor electric shocks when touched, nothing major but enough to cause alarm. It also vibrates a hell of a lot as well. A Sky engineer came out to have a look at it the day after it was installed and told me he couldn’t find anything wrong with it. I'm worried about placing it near other electrical gear, has anyone come across this?
  2. DaveP
    DaveP
    You definitely shuldn't get this! I suggest you report it as being electrically unsafe and get it swapped as soon as possible.
    There is only a 2 wire power lead to these and so the chassis is not earthed.
    DaveP
