gtg60
Established Member
Just changed my V2 Sky+ digibox for a V1 one in preparation for my SDI upgrade and there is a very noticeable degradation in picture quality which I'm not happy about at all.
I'm prepared to live with it if it improves the picture quality once the SDI mod is finished but I'm just wondering if I've got a duff digibox?
Strangely the picture quality on Pal Vs Pal is comparable but with RGB Vs RGB there's a large difference.
Also, I'm going to be using my PC to do the scaling, one of the outputs on the Video card is DVI, would I see a better picture if I was to use that output and a DVI to HDMI cable as opposed to using the standard PC input?
Keith
Keith
