Sky+ V1 box dead???
Discussion in 'Digital TV & Video Players & Recorders' started by LCDRulz, Nov 25, 2004.
Tags:
  1. LCDRulz
    LCDRulz
    Any ideas on what the problems is?
    Power up, drive spins up, red power LED comes on for about 5 secs then goes off. Hard disc continues spinning and RF loopthru works.
    I've tried replacing the drive, get exactly the same problem.
    I've checked the +12vdc, +5vdc and their okay.
    Same prob with all input/output disconnected.
    Anyone know what the PSU outputs on the 19 pin ribbon connector to the mainboard are?
    TIA
    Roy
  2. Flimber
    Flimber
    Sep 22, 2002
    13,679
    Yorkshire
    +4,476
    Try a different HD in it.
    Mike.
  3. swarrans
    swarrans
    Dec 21, 2001
    409
    16
    Kent, UK
    I think he's done that...assuming that he meant hard drive in "I've tried replacing the drive, get exactly the same problem"
  4. LCDRulz
    LCDRulz
    yep,
    twas the first thing I thought of, still the same.
    The question is wether to repair (£80 total from MCES) or replace with Pace V2 box (simply digital total £152).
    Sky stuff is the most unreliable imo, two digiboxes and a sky+ dead over the past 5 yrs :-(
  5. xa200
    xa200
    If you put the original hard drive back in and call sky, they willoffer to send out an engineer to fix the box for £65. If he cannot fix the box he will replace it for a new v2 box. The same thing happened to me and the engineer tried the on/off button on the remote once then swapped the unit.
  6. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,898
    Who says those engineers don't work hard for there money?
  7. LCDRulz
    LCDRulz
    Thanks, I didn't know this. I suppose the downside is I could end up with an Amstrad box :eek:
    Still, since I also have and old duff 40GB I can stuff it with I reckon it's worth a try :p
    Thanks guys
    Westie
