Sky+, using the second feed for another monitor in another room?
Discussion in 'Sky Digital TV Forum' started by Flip., Mar 16, 2006.
  1. Flip.
    Flip.
    This may of been asked before, i have just checked a few threads and couldn't find anything on it.
    Does anyone know if i can use the other feed to my sky+ box (the one that will record whilst watching something else) to run through to another monitor in another room, so that i can watch two independent channels at the same time? Surely??!!
    Otherwise do i need another box to take the other feed from the dish? And presumably another card?
    Any help would be most appreciated.
  2. mh123
    mh123
    Apr 2, 2005
    701
    Offshore UK
    +75
    Unfortunately, option 2.
    If you have Sky+ you will 99.9% likely have 4 sockets available on your lnb (dish), 2 of which are in use for Sky+ and 2 of which are spare.
    What you now need to do is buy or acquire another Sky or Sky+ box (from Sky themselves, eBay or a local dealer), cable it up to the spare port(s) on the dish, and then either:
    a) Get hold of a Freesat card (£20? 1-off charge) from Sky, which will allow you to get the 'free-to-air' channels on your second sky box, or
    b) Get a "Multiroom" subscription from Sky (£10 per month) which will mirror your existing package on the second box.
    Personally I'd have a long hard think about what I wanted to do with the second box and probably buy a £30 freeview box instead! :D
