father alice
Established Member
- Joined
- Nov 30, 2003
- Messages
- 195
- Reaction score
- 6
- Points
- 56
Quick question - a mate currently has sky, and is upgrading to Sky+. The builder installed two runs of cable into the wall (ie 1 feed from dish, and the other from the box to the loft for a loft box) when the house was built.
Obviously sky+ needs two feeds, so can a diplexer be used to combine two feeds from the dish, to the single downlead, then uncombined to provide the two sky feeds. This obviously introduces several joins, so is the signal likely to remain strong enough (no idea if builder used sat grade cable of course!)
Presumably the second installed cable in the wall can remain as an uplead to pipe the sky signal aroubd the house. I guess it is then just a question of if his loft box is compatable with the magic eye tv link system. (don't know what he has).
As you can guess, the point is to avoid having q second direct feed, as the cable is so neatly concealed within the wall at present!
Cheers, Ali
Cheers, Ali
