SKY UPSTAIRS with RGB!
Discussion in 'Sky Digital TV Forum' started by JiMbOb_74, Jun 19, 2004.
  1. JiMbOb_74
    JiMbOb_74
    I am trying to get my sky+ wired up to another tv in my bedroom. It already feeds my 42" pana plasma downstairs.
    I have run a cable up to the bedroom where i have a remote eye for controlling the channels. I want to know how I can connect the rgb from the sky+ to my sony 24" w/screen CRT. when I connect a composite signal the picture on the plasma gets darker. I presume this is because the signal is shared... What cables do i need for the rgb to be passed and also will i need some sort of signal amp.
    Thanks for any help
    James
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    It may be very difficult to take RGB from SKY and feed two seperate displays, there are splitters on the market but they don't come cheap.
    Have you considered using s-video and the phono output for the CRT while keeping the RGB a the source for the plasma?
    Try the Plasma forum, I'm sure this problem has been seen before and maybe solved:)
