sky tv link
Discussion in 'Sky Digital TV Forum' started by theboss, Apr 23, 2002.
  1. theboss
    theboss
    Just bought one of these and installed it without success!everything wired correctly but light on small box doesnt illuminate.anyone installed one of these themselves and had success?? everything done as instructions
    any advice much appreciated
  2. toby
    toby
    Are you using normal sky digital or sky + ??
  3. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Have you turned on the power to the RF2 connection in the installation menus?
    Services - 4 - 0 - 1 - Select
    RF OUTLETS
  4. toby
    toby
    Just what I was going to say! :p
  5. theboss
    theboss
    sky digital and have turned on second rf outlet saved settings .
    i still get my sky picture as before and have to watch whats on downstairs but the small box the light is not illuminated.broken box ??
  6. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    The TVlink is working then and the SKY digital channel is being relayed to the second TV through RF2 it's just that the LED on the link isn't working?
    I can't speak from experience since my TVlink doesn't have any lights on it but maybe the LED only illuminates/responds when you use a remote on the "magic eye".
  7. theboss
    theboss
    boughty sky controller and cannot change channel ?? what else to try ?
    cheers
  8. Zef
    Zef
    Apr 24, 2002
    221
    Hertfordshire
    +10
    have you got anything else "in-line" between your rf-2 and your ilink. basically the ilink people say that nothing should be in between. that includes sockets in the wall. the way round this is to change your sockets to "non-shielded" ones . It worked for me. also make sure nothing else like a booster box is in the line.
  9. theboss
    theboss
    think have found problem,line used is a former cable tv line and it enters another room and has shielded boxes in line so will remove them and hope this works
    thanks for all assistance
    much appreciated
