sky tv in another room remote not working
Discussion in 'Sky Digital TV Forum' started by mkendall, Jan 1, 2002.
  1. mkendall
    mkendall
    My sky remote in the bedroom has stopped working!
    remote is still working the tv so batteries are fine but will not switch sky channels.
    It did this a few weeks ago and i just turned the digi box off at the socket for a minute and it began to work again.But not now!i've checked all settings on the set up as well as the install menu.i've tried turning RF output off and then on again to reset but still will not work
    any help please
    thanks
    Mike
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Sounds like something has broken...
    Have you tried another remote control in your bedroom?
    Have you tried the bedroom remote on the digibox directly and not through a link?
    Does the remote always work after you have reset the digibox?
    Next step would be to try your digibox with another tvlink, if this failed as well then it would point to an internal failure in your box.
