sky to video ?
Discussion in 'Sky Digital TV Forum' started by whizzkid, Apr 4, 2005.
  1. whizzkid
    whizzkid
    help me please!
    despite trying every aerial/scart combination possible i can no longer get sky through my samsung video!
    am i just being stupid or is there a problem?
    are the scarts faulty?
    any suggestions appreciated! :lease:
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Have you selected the right AV input on the VCR otherwise you could have the scart hooked up but the VCR is looking at the wrong input.
    As for the RF connection that may be down to the digibox RF frequency not matching the frequency of the VCR channel number you have selected so either get the VCR to rescan the frequency list (while the digibox is on) or manually check the frequency assigned for both devices.
  3. whizzkid
    whizzkid
    thanks for your help!
    will try again !
    cheers
  4. whizzkid
    whizzkid
    heres a list of where cables are going
    hope someone can tell me what is wrong so that i can get sky through the video
    1 outside aerial sky cable>sky box(dish input)
    2 outside aerial tv cable>video
    3 skybox (rf out 1)>tv (aerial input)
    4 sky aerial in cable>video(tv in)
    5scart video(sat in)>sky box(vcr scart)
    6 scart tv (ext 1)>video (av1 scart)
    7 scart tv (ext2).skybox(tv scart)
    any ideas?i would be very grateful for any help at all!
  5. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    My brain is dribbling out my ears trying to visualise that:)
    It's best to start from the basics.
    Connect the SKY VCR scart to the input scart on the VCR and then connect the output VCR scart to the television scart.
    Turn the digibox on, select the appropriate AV input on the VCR and then select the appropriate AV input on the TV, you should see the digibox video output.
    If that works then there really is no need to have the terrestrial aerial cable routed through the digibox, you can plug it straight into the VCR and then onto the TV.
    The digibox TV scart would then feed the TV directly giving you a better picture (RGB instead of composite) and leaving the VCR to either record the digibox output or record any of the terrestrial channels via the rooftop aerial.
