SKy+ to Sweetspot
Discussion in 'Desktop & Laptop Computers Forum' started by sdu1975, Oct 27, 2005.
  1. sdu1975
    sdu1975
    Mar 12, 2005
    889
    Sheffield
    +18
    I've recently bought a Sweetspot card for my HTPC. Unfortunately I didn't realise that the + box only had one RGB out with the other scart only being RGB in(?) and composite out and in.
    I really need to split my scart RGB signal and was wondering if a simple scart multiplier from argos, maplins etc would work?
    Thanks in advance,
    Stewart
    (I've posted here as anyone who has overcome this problem is more likely to read here)
  2. Rob100
    Rob100
    Nov 3, 2002
    3,485
    +227
  3. sdu1975
    sdu1975
    Mar 12, 2005
    889
    Sheffield
    +18
    Looks perfect.
    Thanks for the reply.
  4. NaTT
    NaTT
    May 27, 2003
    1,123
    Abbots Langley
    +77
    it might be overkill. and I'm a sucker for expensive interconnects
    I get not degredation when using a cheap argos splitter.
    Splitter's plugged into NTL: RGB out, feeds the sweetspot and JS RGB to component convertor (for analogue back-up, when I really can't be ar**d with turning the PC on).
