Sky+ to Sony RDR-GX3 Connection Problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by SourKraut, Apr 26, 2004.
  1. SourKraut
    SourKraut
    Mar 26, 2004
    2,824
    Wonderful Yorkshire
    +347
    Hiya,
    Bit of a newbie here, but I just got a Sony GX3 and I'm trying to link up the Sky+ box to it. I have connected via scart from the Sky+ box to the recorder and then from the recorder to the TV, all on RGB.
    I can get Sky to pass through the recorder and see the programs, but trying to view through the recorder, all I get is a grey screen :confused:
    Any help most welcomed
    Thanks for looking.
  2. Quinny
    Quinny
    Apr 19, 2004
    91
    Cambridge
    Are you still having problems with your set up? I have the GX7 and have not seen this. Have you set the input select on the DVD recorder to 'Input Select 3'? This is located under the sliding door at the bottom of the remote handset or on the control panel of the recorder itself.
  3. SourKraut
    SourKraut
    Mar 26, 2004
    2,824
    Wonderful Yorkshire
    +347
    Quinny,
    Thanks for your reply...I got it fixed now, and I think it was due to me setting the wrong item to input select 3 on the scart settings.
    Sky+ is looped through the recorder to the TVand seems to work fine
    Again thanks for asking:smashin:
  4. Quinny
    Quinny
    Apr 19, 2004
    91
    Cambridge
    No problem. I hope you enjoy it!
