Sky+ to Sky HD - new cables req?
Discussion in 'Sky Digital TV Forum' started by Trick, Feb 8, 2009.
  1. Trick
    Trick
    Jul 23, 2004
    22
    4
    Northamptonshire
    Im having HD fitted today, currently have sky+
    are any extra cables required to be fitted for HD?
    I ask because when i had SKy+, the installer refused to go into my loft and wanted to lay cables OVER my roof. I said no way - i`ll go in the loft and feed the cables through. now my cables are all tucked out of sight.
    If new cables are required, i need to shift some stuff round in the loft before the installer gets here.
  2. kenedin
    kenedin
    Aug 19, 2008
    1,719
    Edinburgh, Scotland
    +312
    Given the layout of your cables, new ones should not be necessary if all is well when the installer checks Signal Strength during the install. You should, however, get a new LNB on your dish. HDMI cable comes supplied.
  3. Trick
    Trick
    Jul 23, 2004
    22
    4
    Northamptonshire
    thank you.
