Sky to Sanyo Z2
Discussion in 'Projectors, Screens & Video Processors' started by Mikeg247, Jun 8, 2004.
  1. Mikeg247
    Mikeg247
    Feb 29, 2004
    193
    Northants
    +6
    I want to get Sky digital to my Z2. Will this Scart adaptor work? It says 'These adapters allow you to breakout or breakin audio, video and s-video from / to a scart lead without having to touch the scart cable'. It would then allow me to connect a 10m s-video cable to the Z2.
    [​IMG]
    Thanks in advance
    Mike
  2. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    that one would be average, it converts to stereo audio and composite video (at least that is what it looks like). Composite will look pretty dire on any big screen. At minimum you should look for an svideo connect
    ad
  3. Mikeg247
    Mikeg247
    Feb 29, 2004
    193
    Northants
    +6
    It has s-video too. So it will work then?
    Mike
  4. Rickyj @ Kalibrate
    Rickyj @ Kalibrate
    Well-known Member AVForums Sponsor
    Jan 29, 2003
    5,683
    Surrey
    +1,692
    I have just had one of these delivered, so that I can connect my vcr/ntl box to my panny ae300 (via s/video). Will try and test tonight, and will let you know the results, as I am sure the Z2 will have similar results.
    Ricky
  5. Gavin_Hall
    Gavin_Hall
    Apr 18, 2001
    807
    46
    Maidstone, Kent
    +112
    It will only work if your Digibox can output Svideo. So unless you've got a Sky+ unit, or one of the Grundig units with svideo facilities, it's not going to work :confused:
    cheers
  6. Geoffc10
    Geoffc10
    Gavin is correct, if the digibox only outputs rgb then you can buy a rgb to svideo convertor £50. This is what i use.
  7. Liam @ Prog AV
    Liam @ Prog AV
    Oct 18, 2002
    8,498
    Kent
    +827
    The scart adaptor simply connects the pins in the scart plug to their respective s-video, composite video or audio connections on the back. It doesn't do any conversion and requires the scart plug to be sent an s-video picture in the first place for the s-video output to work.
    e.g. the JS RGB to SVHS converter uses scart sockets in and out, the our one carries an SVHS signal. This adaptor would be used to extract the s-video signal to a 4pin din socket for use with a straight SVHS lead
    HTH
  8. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Lytham St Annes, where people are put out to grass
    Mike you want a scart to VGA adaptor for Sky from Keene with a vga DVI dongle about £30 in total. Works a treat RGB through input 2 on Z2.
    Im using these with a good quality 10m VGA cable and have no problems
  9. Mikeg247
    Mikeg247
    Feb 29, 2004
    193
    Northants
    +6
    Thanks Guys
    Mike
