Sky+ to projector
Discussion in 'Desktop & Laptop Computers Forum' started by stevos, Dec 16, 2004.
  1. stevos
    stevos
    May 16, 2004
    5,979
    +541
    I am currently using an s-video lead from my sky+ box into my Sharp VX-9000 projector.
    The current picture quality is terrible (at best).
    I was wondering what my options are and what effect they would have to the picture.
    So far I have considered
    1. A RGB Scart to RGB Component lead
    2. Using a HCPC, and using a bit of video processing
    Has anyone tried either of these? are they worth the outlay.
    On the HCPC side, I currently have a laptop (Intel 2400 mobile, Nvidia Geforce 4 440go, 512 MB ram) which I don't think is going to be good enough for the job. If I was to invest in a desktop, can anyone recommend a fast (for games) graphics or addon card that can input an RGB scart signal?
    Sorry for the long winded question
    Thank you in advance.
    Stephen
  2. Embarker
    Embarker
    Apr 19, 2004
    1,626
    Garden of England
    +66
    a sweetspot card will allow for RGB in.
    The cheapest way is with dscaler and a svideo capture card - pcworld do them for £30, you'll get good results with a very modest pc
  3. dan1979
    dan1979
    Sep 16, 2004
    3,520
    83
    +201
    I would have thought you would be able to get some sort of USB box that allows a video input to be plugged into your laptop. Then run the input through Dscaler.
    I have a TV card in my desktop and a Telewest digital box connected via composite, the picture is cack but with dscaler there is a huge improvement, I assume you'll get much better results from s-vide.
  4. stevos
    stevos
    May 16, 2004
    5,979
    +541
    Where do i get the nvidia codec from?
