Sky+ to Plasma
Discussion in 'Plasma TVs' started by steevs, Aug 21, 2003.
  1. steevs
    steevs
    Jan 3, 2003
    2,871
    68
    wxm
    +71
    Need a little advice guys and gals.
    I was wondering if it was possible to acheive a RGB picture on my Relisys Plasma from my Sky+ box, I have no scarts on my plasma only composite, component and s-video. Currently I have it connected via a scart to phono lead, can I improve on this because I'm none too happy with the picture quality.
    Thanks for listening.
    Steve
  2. ajb
    ajb
    Jul 17, 2001
    445
    Chester Area
    +8
    Hi mate
    I live not far from you- any help required, let me know.
    It looks to me as if you need a RGB->YUV box and then you can run it into the component inputs.
    Regards
    Andrew
    PS Where in Wrexham you from?
  3. steevs
    steevs
    Jan 3, 2003
    2,871
    68
    wxm
    +71
    Thanks for the info, can you point me to a website that sells the item you describe. I'm from Hightown, about a mile away from the town centre. Thanks for your help.
  4. deman77
    deman77
    Aug 20, 2003
    260
    16
    London
    js-technology.com makes and sells it
    av-sales.co.uk sells it
    tmfsolutions.co.uk sell it
    you need to configure your SKY+ to output in RGB for best results and turn the contrast in SKY+ right down.
  5. Dave777
    Dave777
    Oct 25, 2002
    479
    Gatwick
    +8
    In the short term you could always use an s-video to s-video as the SKY+ box has an s-video out which gives a better picture than composite.
    Dave
  6. steevs
    steevs
    Jan 3, 2003
    2,871
    68
    wxm
    +71
    Thanks for your help , its much appericiated, just one last query, I took a look at the JS products and saw that there are 2 types of converters for plasma, the RGB to Plasma Screen VGA and the RGB to Component (YUV) Converter, I was wondering which gives the better results as I have both connections on my Plasma.
  7. jmack
    jmack
    on the panny/toshiba the vga gives a slightly sharper picture than the component converter but you have more control and picture settings with component,
    before you order drop js tech an email with your Relisys Plasma specs to make sure they are compatable
