sky to plasma
Discussion in 'Plasma TVs Forum' started by steevs, Feb 2, 2003.
  1. steevs
    steevs
    Jan 3, 2003
    2,910
    68
    wxm
    +72
    Hi guys
    Just wondeing how would I get the best results connecting my sky+ digibox to plasma. thx in advance
    Steve
  2. Rob100
    Rob100
    Nov 3, 2002
    3,482
    +227
    What plasma do you have? Also how much do you want to spend to make the connection? You can spend as little as £5 or over £1000...
    Rob.
  3. DaveCheltenham
    DaveCheltenham
    Oct 16, 2002
    396
    Cheltenham
    +49
    Rob - Both S-Video and RGB-Sync work very well with Sky+ asuming you have these input connections.
    Making the RGB connector yourself will cost about £10 and you can buy good quality S-Video (2 metres) ones for about £5 depending on where you go.
  4. steevs
    steevs
    Jan 3, 2003
    2,910
    68
    wxm
    +72
    I have a relisys plasma, I also have a pro v scan box from keene electronics which I think has improved the picture a little.
    I'm looking for a lo cost connection method really maybe somewhere in the region of £100.
  5. steevs
    steevs
    Jan 3, 2003
    2,910
    68
    wxm
    +72
    Dave - Forgive my ignorance, the RGB sync is carried through scart right? I do have scart on sky+ but only vga, component, composite and s-video on the plasma. Thx for the suggestions guys
  6. DaveCheltenham
    DaveCheltenham
    Oct 16, 2002
    396
    Cheltenham
    +49
    On your component input, you will have 5 connections; use the R, G, B and certainly on the Panasonic input board, you can set this for RGB and use the video/S-Video as the sync input. There have been quite a few posts on this which you will find by doing a Search. This gives superb results closely followed by direct S-Video from a Sky+ unit.
    Hope this helps.
  7. steevs
    steevs
    Jan 3, 2003
    2,910
    68
    wxm
    +72
    I'll give that a go, thx for the help dave
