SKY+ to Plasma with no SCART Connection.
Discussion in 'Sky Digital TV Forum' started by gosman, May 9, 2005.
  1. gosman
    gosman
    I have just purchased a Samsung 50" Plasma and I want to connect my SKY+ box to it. My house is AV wired as following. On the wall behind the plasma I have a wall plate with 3 phono sockets RGB. This terminates to another wall plate where my AV equipment is kept. So this is the only method I can use to connect anything to the plasma. Is there a SCART cable I can purchase that will convert to Component.
    The Component specifications on the plasma are.
    Component 1 In Y/Pb/Pr (RCA, 3P, 480i ~1080i)
    1. If there is such a cable. Where can I buy it?
    2. Do I need to change any settings in the SKY+ system setup?
    Thank you in advance.
  2. Mep
    Mep
    Dec 25, 2004
    9,502
    +460
    dont think so but js technology do a scart to component converter
  3. Calpolaholic
    Calpolaholic
    May 19, 2004
    542
    46
    +103
  4. Mep
    Mep
    Dec 25, 2004
    9,502
    +460
    great minds :)
  5. gosman
    gosman
    Thanks Guys.
    Anybody know what the SKY+ quality is like through one of these?
  6. Mep
    Mep
    Dec 25, 2004
    9,502
    +460
    its excellent with the scart to vga version and with the component you get more control over colour and other settings
