Sky + to plasma, advice
Discussion in 'Sky Digital TV Forum' started by Vish, Nov 5, 2004.
  1. Vish
    Vish
    Nov 2, 2004
    7
    I was looking on the maplin website and i found a Scart Sync Separator,
    it has a RGB sync input from a scart and it outputs with RGB plus separate Horizontal & Vertical Syncs using 15pin inputs.
    I was thinking that might work with my Panasonic PW6.
    Hope someone can help
    Vish
  2. DaveP
    DaveP
    This is supposed to be the best solution. Not sure how it compares to the Maplin pricewise!
    Dave
  3. Vish
    Vish
    Nov 2, 2004
    7
    Thanks for the advice,
    The Scart Sync Separator is £49.99
    order code is L05AN incase anyone wants a look.
    www.maplin.co.uk
    Vish.
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    There's nothing you can't make worse by making it cheaper. You've spent £1600 plus on a screen, if you get cheap on the connections you will pay the price in poorer picture, and less reliable operation. The JS is the mercedes of converters, and you are considering the Yugo.
  5. pezzer
    pezzer
    Jun 9, 2004
    194
    West Sussex
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    And that is the ford fiesta. It works, most of the time. I have tried them all, and now only fit 1.
  7. pezzer
    pezzer
    Jun 9, 2004
    194
    West Sussex
    Ummm - reviews of syncblaster in what video and widescreen tv (listed on this site ) would suggest more than a ' fiesta'.....
  8. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    In the light of experience, I beg to differ.
