Sky + to panny 700 best connection
Discussion in 'Cables & Switches' started by kennyjmac, Nov 18, 2004.
  1. kennyjmac
    kennyjmac
    Oct 5, 2004
    longridge
    can anyone help me regarding a cable from sky + box to panny 700 i have a ixos 6 core cable and have had a problem with pq on s video connections to it ? :lease:
  2. thfccambs
    thfccambs
    Jul 17, 2002
    18,952
    White Hart Lane
    +5,007
    I have my ae700 conected to sky+ using scart and the picture quality is excellent.
  3. kennyjmac
    kennyjmac
    Oct 5, 2004
    longridge
    did u make up your own cable or was it a bought 1 any settings did you have to change ?
  4. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,084
    38
    NW London
    +9
    buy it - www.tvcables.co.uk seem to be pretty goos, even with delivery it aint much more than £20 if you keep cheap. I dont notice a difference personally but I know some people may. You just plug in the cable (must be RGB cable - tvcables ones are mostly), then enable the RGB out option in the Sky + picture settings. Turn the Proj onto Scart and your flying.
    Great picture!
