Sky + to my Laptop ?
Discussion in 'Sky Digital TV Forum' started by wrcguy, Aug 30, 2005.
  1. wrcguy
    wrcguy
    I have yet to buy a DVD Recorder so in the meantime, I was wondering if it is possible to copy from my Sky + Box direct to the DVD-R on my laptop ?
    I only have USB & RS232 connectors on the back of my laptop.
    If anybody knows if this is possible, I would be grateful for any help or advice on this ?
    Many Thanks
  2. SeanT
    SeanT
    Jan 28, 2005
    6,163
    Coventry
    +368
    you'll need to get a USB TV capture card, preferably with S-video so you can take advantage of that output on the sky+ box, and some capturing software. You'll need to copy the recorded material to the hard drive (on the laptop) first, then you'll be able to burn it off.
  3. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
