Sky+ to laptop over wifi
Discussion in 'Desktop & Laptop Computers Forum' started by Langers, Aug 10, 2005.
  1. Langers
    Langers
    Is this possible in any way?
  2. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    yes, you need to use a PC capture card , and then some software to encode the video and audio (e.g. www.videolan.org)
    You can choose different bandwidth levels and encode methods on videolan to suit your network, with regular b spec wifi then dont expect great quality, but with the higher g bandwidth you should get something pretty good...
    as always the quality of the delivered video is dependent on the source, so if you want to do it 'properly' then prepare to invest in a decent capture stage.
    regards
