Sky+ to Iscan HD+
Discussion in 'Projectors, Screens & Video Processors' started by telboy, Oct 29, 2005.
  1. telboy
    telboy
    Jan 24, 2002
    55
    Kent
    I have just purchased an Iscan HD+ and I need to connect my Sky+. Which is the best option.
    I tried S-Video but this only carries the low res PAL signal and not RGB. I have a QED AV29 cable which is directional RCA to the Scart, the AV19 seems to be the opposite, can I adapt the AV29?
  2. binbag
    binbag
    Jun 16, 2004
    1,717
    North Kent Coast, SE UK
    +81
    RGBs is the best option with an unmodded Sky+. I don't know about your QED cables. I'm using a component cable and a single phono attached to a scart end which cost £6 from Keene.
  3. Ianfromnotts
    Ianfromnotts
    May 16, 2003
    2,763
    Nottingham
    +174
  4. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    4,528
    137
    Middle Earth
    +1,007
    You need the QED AV19 cable, I use two of them. £55 or something onthe web. Very good quality cable, not usually in stock though, so have to be ordered so expect to wait a week for it.
  5. Ianfromnotts
    Ianfromnotts
    May 16, 2003
    2,763
    Nottingham
    +174
    Am I missing something here - I didnt know that you could input RGB into the HD+ ?
  6. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    4,528
    137
    Middle Earth
    +1,007
    Yes as long as it's RGB + SYNC. The AV19 takes the RGB feed and also gives you a SYNC from the composite. You then plug the RGB+SYNC of the AV19 into the back of the iScan and leave the L+R audio not plugged in. This way you have one less box etc. It must be RGB+S though as RGB alone will not work I don't think.
  7. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,847
    Alvaston/Derby
    +265
    The iScan HD & HD+ both accept RGB with sync on composite, so all you need is a scart to 4 phono. Works a treat.
    Charlie
  8. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,847
    Alvaston/Derby
    +265
    Snap!
  9. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,847
    Alvaston/Derby
    +265
    telboy I forgot to mention if your willing to cover the post Ive got a few & your welcome to borrow one to try it.
    Charli
  10. Ianfromnotts
    Ianfromnotts
    May 16, 2003
    2,763
    Nottingham
    +174
    Just had a look at the back of the box and concur never thought of it before
  11. telboy
    telboy
    Jan 24, 2002
    55
    Kent
    Thanks for the replies. Surely the QED AV29 is the same as the AV19 with the exception that it is directional i.e. RCA to Scart, if so it probably only needs a pinout change at the Scart end to reverse the direction. Does anyone know which pins need changing?
  12. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    4,528
    137
    Middle Earth
    +1,007
    Yes, I'm sure if you know which pins to change around (RGB-in to RGB-out, composite, L+R audio and -ve etc) then it will work no problem.
  13. nicke20
    nicke20
    Oct 11, 2003
    885
    +13
    well speaking from experience get along to mark grant in the powerbuy forum, he will do you a fantastic scart to component + sync cable that will knock spots off the others at a great price too!
    would you realy buy a plasma and hd+ then use a £6 cable ???
  14. binbag
    binbag
    Jun 16, 2004
    1,717
    +81
    I can recommend the £6 scart block but I could never live with the poor PQ of a plasma... :rolleyes:
  15. nicke20
    nicke20
    Oct 11, 2003
    885
    +13
    well you aint seen a good plasma then :rotfl:
  16. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,847
    Alvaston/Derby
    +265
    I agree with nicke20, I've had my plasma for about 3 years & I'm happy with the picture.
    charlie
  17. binbag
    binbag
    Jun 16, 2004
    1,717
    +81
    Not yet. But who knows with time and science anything is possible. :devil:
    To bring this back towards the topic(ish). I'm nearly ready to go SDI on my Sky+ box. Any 'If only somebody had told me that" tips before I start?
  18. telboy
    telboy
    Jan 24, 2002
    55
    Kent
  19. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,847
    Alvaston/Derby
    +265
    No, you need 4 phono (RGB + sync).
    Charlie
  20. telboy
    telboy
    Jan 24, 2002
    55
    Kent
    Clamicpo1
    I thought the Iscan can take in RGB and/or component. Is it the Sky digibox that is preventing H & V sync?
  21. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,847
    Alvaston/Derby
    +265
    The iScan can accept RGB but the Sky+ needs the sync on composite to work ie; RGBs. as I said before your welcome to borrow a lead for a week or 2 to try it out (this is a loan not a sale, I'll want the lead back).
    Charlie
  22. telboy
    telboy
    Jan 24, 2002
    55
    Kent
    Thanks for the offer.
    I will try to change the pins on my QED AV29, if all fails I may take you up on the offer.
  23. BeelzebubUK
    BeelzebubUK
    Feb 19, 2004
    607
    Milton Keynes
    +24
    Same here - Mark did a cable for me a couple of weeks ago. Excellent picture quality.
  24. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    Mark Grant's Scart to RGBS (or RGBcvS as some people drone on) cable is fantastic, can not recommend enough.
    StooMonster
