Sky+ to DVI
Discussion in 'Projectors, Screens & Video Processors' started by dion, Apr 29, 2005.
  1. dion
    dion
    I am looking to convert Sky+ SVHS or RGB to DVI so I can feed my Domino30H with just 1 cable (HDMI) 15M run using a chord silver cable from my Denon 3910 at the moment with no problems.
    I am considering the Denon AV 11Xv as an upgrade from my current 3805 which I believe provides DVi/HDMI switching some adverts on suppliers web sites state it does conversion to HDMI as well! Advice would be appreciated as I really dont want to run a component, SVHS cable to the projector.
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Dion
    There's now a Denon forum so maybe you might get an answer there
    Jeff :rtfm:
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,429
    The Borders
    +2,593
    dion
    I'd suggest a decent quality external Video Processor with multiple Analogue and Digital Video Inputs is the best option.
    With the likes of a Lumagen VisionHDP you can set the processor to Output 1280x720P and undertake the required deinterlacing and scaling within the Video Processor and connect to your Projector on a Single Digital cable.
    A Video Processor such as the Lumagen will be more flexible than using any AV Receiver - I'm pretty certain too the Denon unit you mention only scales Analogue signals. The Digital Switcher and Analogue Switcher + DCDi Deinterlacer + DVDO Scaling engine are on separate signal paths.
    Any questions do please shout.
    Best regards
    Joe
