Sky + to Davs 550 audio connection
Discussion in 'Sky Digital TV Forum' started by PaulBrum, Oct 21, 2003.
  1. PaulBrum
    PaulBrum
    Apr 15, 2003
    138
    Solihull
    whats the best way to connect sky+ to my sony davs 550 for audio output.
    Sky + gets delivered tomorrow (have a Grundig digibox at the moment)
    I currently have a thor scart connecting digibox to tv (RGB) and have used fairly cheap audio interconnects from the digibox to the davs unit for sound.
    Any thoughts would be appreciated
    Paul
  2. duncs
    duncs
    The best way is to use the optical ports. I believe that this is the only way to get true 5.1 from the Sky+ box to your 550.
  3. PaulBrum
    PaulBrum
    Apr 15, 2003
    138
    Solihull
    I thought this might be the case, but wasnt sure if optical carried sound (durr) - anyone recommend some good leads - any more feedback ????
  4. scottymc^^
    scottymc^^
    Hi i got a sony davs550 and Sky+
    im using a optical cable called monster from comet think it was about 25 quid works fine
    Do higher priced ones work any better ??
  5. PaulBrum
    PaulBrum
    Apr 15, 2003
    138
    Solihull
    one more question - is it a toslink connector i need ?
