Sky+ to all TVs
Discussion in 'Sky Digital TV Forum' started by jimcarney, Sep 10, 2003.
  1. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    Hi ,At the moment Im using my VCR to relay Sky to all the TVs we have in the house, via a distribution box if I get Sky+ will I be able use the same set up to view different Sky channels on another TV .
    Jim
  2. Easy2BCheesy
    Easy2BCheesy
    May 8, 2003
    343
    16
    Yes you can, I'd recommend using the VCR SCART connected to your distribution box, and then use the TV SCART connected to your main TV to benefit from the RGB picture.
  3. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +10
    You will need to be careful if you want to use a remote eye in another room from the RF2 Out, you can but you can buy distribution amps that will pass the signal through, I think Maplins do them.
  4. UrbanT
    UrbanT
    Jan 6, 2002
    12,873
    Aldershot, Hants
    +3,034
    Can you point me in the direction of a 'distribution box' ?
    I have just ordered Sky+ and also route Sky around the house through the VCR into a splitter/booster but its fairly old equipment.
  5. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    Hi UrbanT,The one I have is in the roof space it has2 imputs 1 UHF 1 VHF 4 outputs ,we have 4 tvs linked to it via VCR from main TV setup,I have had at least 10 years its a product made by Labgear Model C M 7094 they are based in Cambridge or least the were when I bought it Ive seen similar ones in B&Q ,Maplins etc .
    Jim
  6. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +10
    Look on the Maplins web site for the following If you do not already have a booster and want to use a remote Eye try L22AG (different versions available depending on how many outputs you need), if you already have a booster but the Eye does not work try L30AG.
