Sky + Time
Discussion in 'Sky Digital TV Forum' started by ratty369, Nov 30, 2004.
  1. ratty369
    ratty369
    Hi does anyone else have a problem with time on sky +, the time on my system slowly starts to lag upto 10mins behind the correct time, The only way to correct it is to pull the power out the back of the box.
  2. mansell
    mansell
    Feb 11, 2002
    754
    28
    Bristol
    +39
    I've had a similar problem in which the banner time does lag behind but then all of a sudden catches up, I don't nee to disconnect power however.
    Yesterday we had our box swapped so hopefully this will resolve the problem.
  3. jackuzi
    jackuzi
    Dec 3, 2001
    253
    16
    South Wales
    I've just had sky installed and have the same time problem. Has varied up to about 20 minutes behind. Obviously this causes hassle when you want to record something. I'm going to ring them tomorrow. Have had other issues as well such as losing the listings. Getting hacked off rebooting the box. :rolleyes:
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    It's a known problem with the Amstrad Sky+ box. Should be fixed in a future firmware update.
  5. jackuzi
    jackuzi
    Dec 3, 2001
    253
    16
    South Wales
    Got engineer coming on Thursday. Going to try to see if I can get a Pace box replacement.
  6. jackuzi
    jackuzi
    Dec 3, 2001
    253
    16
    South Wales
    Engineer called today, now have a Pace unit instead...YAY (I think?!?!).
  7. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    I have an Amstrad and have NEVER seen this problem. Is it the channel you use I almost never never use ITV.
  8. jackuzi
    jackuzi
    Dec 3, 2001
    253
    16
    South Wales
    No the problem was the time was out by about 15 minutes behind, nothing to do with ITV. This obviously causes problems with recording. Engineer said that Sky are awaiting a firmware release that will fix the problem. He said that they have issues with 5% of Amstrad boxes.
    All I can say is good luck.
