  2. Notice: AVForums will be offline at 10pm for no longer than 30 minutes for scheduled maintenance. Apologies for any inconvenience this causes.
SKY + Time Lag
Discussion in 'Sky Digital TV Forum' started by mansell, Dec 3, 2004.
  1. mansell
    mansell
    Feb 11, 2002
    754
    28
    Bristol
    +39
    I'm now on my 2nd box and still getting problems , last night a reminder appeared for only fools and horses 10mins after the program had started.
    On checking the banner time I found it lagged 10mins behind the real time.
    I'm using the latest SW version
    Is anyone else getting such problems ?
  2. JonBClark
    JonBClark
    Yes I'm getting the same lag..
    Putting on standby doesn't seem to fix. My only remedy is to use channel up/down button to change to another channel and then back to your original channel.
    I think if you have paused a programme it gets a bit confused..
    I wonder if this has been raised with sky?
  3. Don Peter
    Don Peter
    Yes, I have been having this too. Also, changing to channle 109 initially rectified the problem, but when it happens now, changing makes no difference at all.
    What I have noticed is, when the time is lagging, say for example the real time is 9pm but Sky+ says 8:50pm, and you change to a channel where a programme is starting at 9pm, the correct 'Now' is indicating in the bar, but also underneath, the same program
    is indicated as 'Next'.
