Question Sky through to another room
Discussion in 'Home Cinema Building DIY' started by stuartbennett74, Oct 30, 2017.
  1. stuartbennett74
    stuartbennett74
    Jan 25, 2017
    13
    3
    Belfast
    +11
    I hope someone can help me - I have sky hd installed in a room and want to run it into another room - I have a dead satellite extension cable that can be removed and replaced - is there a better cabling option out there?
  2. hands197
    hands197
    Jan 10, 2010
  3. _Darren_
    _Darren_
    Jul 21, 2007
    247
    +10
    Upgrade to sky q
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,843
    The Borders
    +3,544
    Do you mean you want to move the SKY+ HD box to the other room or you want to be able to view it in two locations simultaneously?
    Joe
  5. stuartbennett74
    stuartbennett74
    Jan 25, 2017
    13
    3
    Belfast
    +11
    Thanks for the replies guys - I'm wanting to run the sky box in a different room from where the sky cables come out from the wall - I had previously run satellite extension cable through the wall low down at carpet level - this cable has failed so I need a replacement approach
    If I move to sky q it must be the 2 TB box going in there so I think I'm right in saying it needs to be connected by these cables?
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,843
    The Borders
    +3,544
    If you go with SKY Q you will likely find the SKY Installer will want to replace the Dish to Box cabling anyway - ensure they lay it through to the room where you now want to place the SKY Q box.
    Joe
