Sky through Home Cinema?
Discussion in 'Plasma TVs' started by ngk2112, Aug 20, 2003.
  1. ngk2112
    ngk2112
    Aug 20, 2003
    12
    I have been reading through several of the current threads on this forum. They are very similar to a problem that I currently have so hopefully someone can give me some advice.
    I have a Hitachi PMA400 connected to a Sony DAVS550 Home Cinema system via 3 Component Video leads. The picture is great when running DVDs. I want to connect a Grundig digibox up to the current system but I don't want any more leads connecting to the plasma. I want to run everything through the 3 component video leads. Does that mean I have to connect the Grundig to the Sony ? The only way it appears that I can do that is via the Scart on the Grundig (TV Out) to the 3 phono sockets on the Sony (Red,White,Yellow) using a Scart to Phono converter socket supplied with thenSony. However, that doesn't work.
    Can anybody help?
  2. philipb
    philipb
    Mar 6, 2002
    1,989
    63
    Swindon
    +132
    You can't do it, mainly because the Grundig does not output component video and the Sony does take a component input. The phono inputs on your Sony are composite video plus L+R audio - not component video, and I suspect they are outputs not inputs but I don't know the Sony so could be wrong.
    You either need the Netgem digibox which outputs component video from the SCART socket, or pass the RGB output from the Grundig via a RGB/component converter (John Sims is the best). Either way you need to get 2 component feeds into a single component input on the Hitachi, so you need a component switcher. Scancom (?) does them for about £80 I think.
    There are other options for getting the Grundig output into the display - what inputs does the Hitachi have?
  3. philipb
    philipb
    Mar 6, 2002
    1,989
    63
    Swindon
    +132
    Sorry - should have said the Sony does NOT take a component input.
  4. ngk2112
    ngk2112
    Aug 20, 2003
    12
    Hi Philip.
    The Hitachi has multiple inputs (special card supplied with the screen) however, as it is mounted on a wall I simply want to channel everything through the high quality component video leads (I was told that they are the best way to connect?)
    The manual with the Sony implies that a digibox/sat receiver can be hooked up to it through the route I have described although the 3 connections that I have described are directly above the component video outputs so I suspect that you are right, I am connecting the output from the digibox to the matching output on the Sony, hence no picture.
    I was hoping to be able to buy a specific cable that would resolve the problem but it doesn't appear possible.
  5. philipb
    philipb
    Mar 6, 2002
    1,989
    63
    Swindon
    +132
    If the hitachi has a VGA input, then an alternative to component (better many would say) is to convert the RGB output from the digibox to a VGA signal using another of John Sims' magic boxes (cheaper than the component version), then hook up to the plasma. A second input I know, but trying to channel it all through the component input is going to cost a lot in terms of converters and switchers.
  6. ngk2112
    ngk2112
    Aug 20, 2003
    12
    Thanks, Philip.
    Does that imply that even if I use the correct lead(s) from the Scart connector on the Digibox to the back of the DAV S550, I still won't receive any Sky output on the plasma ?
    ie; I can't channel Digibox output through the DAV to the plasma ?
  7. Dutch
    Dutch
    Dec 5, 2002
    2,598
    3
    North Yorkshire
    +282
    Philip,
    I don't believe the Hitachi can take the output from a JS Tech RGB to VGA converter - unsupported frequency I think.
    ngk2112,
    I think your best bet would be to use an RGB to S-video converter output to your plasma, presuming your Grundig isn't one of the models that can output S-video. The audio could be routed to the Sony for amplification and de-coding. Hope this helps.
    Steve
  8. philipb
    philipb
    Mar 6, 2002
    1,989
    63
    Swindon
    +132
    Dutch's idea is probably the best combination of quality and efficiency.
    Still think it might be most cost effective though to ditch the Grundig and spend some money on a Netgem digibox. The Scart can be configured for composite, s-video, RGB or component. Start off by using the s-video to the Hitachi as Dutch suggests at only the cost of a scart to s-video lead, maybe upgrade later to the component out if and when you can afford it.
