Sky+ Svideo Through Denon Avr1905 To Sagem Hd45
Discussion in 'General TV Discussions Forum' started by cbridge, Jun 23, 2005.
  1. cbridge
    cbridge
    Apr 14, 2005
    7
    The only way that I can take video from my SKY+ box, through my Denon AVR1905 and back into my new Sagem HD45 TV is via S-Video.
    (I'm taking the sound through the optical in)
    If I view the output from the Denon on the Sagem TV (through the S-Video) the picture quality on SKY+ is poor[er]. Although the picture is not too bad, the display on the 'search and scan banner' in SKY suffers badly from jagged edges (anti-aliasing I think its called?).
    If I take the output directly from SKY+ (Scart) to my Sagem TV the picture quality is much better, and the jaggies disappear.
    Has anyone else experienced this? is this what I can expect if I run the signal through the Denon AVR?
    I miss the ability to see the Denon's volume control (through the monitor composite video) on the Sagem's screen. But I just can't bring myself to live with the poorer quality picture.
    Maybe I just have to wait for SKY HD version? but if I get that I suppose I'd end up with a similar situation.. I'd be pushing the HDMI->DVI output straight from SKY+ HD to the Sagem TV and by-passing the Denov AVR?
  2. Razor
    Razor
    Dec 15, 2004
    37,567
    2
    +12,435
    :hiya: cbridge
    For best results you should always do a direct connection. Passing the signal through an amp was great for displays with limited connectivity but the Sagem has pleanty of connections so this isn't a problem. :thumbsup:
    Is it that important to see what the volume is? :eek:
    Try doing this with all your equipment you will see the difference. If you have a DVI/HDMI dvd player use this connection, if not use component.
    Sky is best on RGB scart.
    Leave your amp just for sound.
    :thumbsup:
  3. cbridge
    cbridge
    Apr 14, 2005
    7
    thanks for the info, it's as I suspected.. just waiting for my Samsung HD945 DVD player now to test the DVI input on the TV :)
  4. Bacus
    Bacus
    Dec 30, 2004
    8,595
    Close to the sea
    +2,709
    Does your denon amp convert all input signals to component output ?
