  2. Notice: AVForums will be offline at 10pm for no longer than 30 minutes for scheduled maintenance. Apologies for any inconvenience this causes.
Sky + Svideo Quality
Discussion in 'Sky Digital TV Forum' started by dblake, Jul 8, 2003.
  1. dblake
    dblake
    I've recently purchased Sky + with a 42" Hitachi plasma monitor. I connect the two together with a 5m Svideo cable. Some channels are fine but others offer poor quality. Up close images are very sharp but anything in the background seems blury.
    Sky have told me that using the Scart with RGB is a better option. So I'm thinking of buying a £75 box that converts Skart RGB to component and then connecting this to the Plasma.
    Am I going to improve the blury images??
    Many thanks
    Dave
  2. mediamogul
    mediamogul
    Jan 25, 2002
    490
    Chatham,Kent
    +18
    I use SVHS from my sky+ to my barco projector and the picture is perfect. It does go through a scaler and line doubled.The best plasma pictures i have seen have been through a scaler.
  3. dblake
    dblake
    Whats a scaler?
    Dave
  4. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    You have to remember all the channels broadcast at different bitrates so the quality varies a lot, you might simply be seeing a lack of PQ in a low bitrate/high compression channel which is more obvious now you have a large plasma display.
  5. mediamogul
    mediamogul
    Jan 25, 2002
    490
    Chatham,Kent
    +18
