Answered Sky supplied hdmi cable.
Discussion in 'Sky Digital TV Forum' started by jrh1, Apr 18, 2016.
  1. jrh1
    jrh1
    Jul 1, 2007
    64
    Is it a high speed hdmi cable?
  2. Best Answer:
    Post #3 by andy1249, Apr 18, 2016 (1 points)
  3. logiciel
    logiciel
    Feb 2, 2008
    52,973
    UK
    +5,718
    There's no such thing.
  4. andy1249
    andy1249
    May 7, 2006
    8,221
    +2,383
    Best Answer
    Presumably you mean is it rated as standard or high speed as per HDMI guidelines.
    HDMI :: Manufacturer :: HDMI 1.4 :: Finding the Right Cable
    If its not carrying one of the logos pictured, then its not rated at all, that doesnt mean it wont work, it just means sky didnt pay the 20k or so it costs to have a cable manufacturing line rated.
    Sky operate at 1080i for now, that only requires the standard speed logo/ suite of tests. Pretty much any functioning cable can do that.
    But also Sky supply short cables only, so should be able to handle just about anything you can throw at it, same as any other short HDMI cable.
    In general, assuming half decent mechanical quality, you only run into issues with HDMI cables at 8 meters or more.
    • Like Like x 2
    • Agree Agree x 2
    • List
