sky subscription for hd in two rooms - any way round it?
Discussion in 'Sky Digital TV Forum' started by bluesteel, Dec 21, 2006.
  1. bluesteel
    bluesteel
    Sep 19, 2004
    652
    +20
    heres the problem
    i have hdsky in my lounge via hdmi into a projector
    but......ive just acquired a 50 inch plasma and want to put it in my conservetory
    i rang sky who want an extra 300 quid for the additional box AND £10 per month for the multiroom tariff
    but what amazed me is they also want £10 per month for the additional HD subscription
    What can i do can i buy a box and swap my card from room to room?
    or do i have to bite the bullet and shell out for the 20 quid a month plus 300 for the box?
  2. bcopping
    bcopping
    May 24, 2005
    508
    28
    Brecon
    +46
    The cards are synchronised to the box
    I haven't tried it but i think you could spend the £300 on a hdmi/component splitter and cables to get the hi def signal to another room and a magic eye to control the box. But you will be forced to watch the same channel in both rooms. Saving you the £20 per month.
  3. bluesteel
    bluesteel
    Sep 19, 2004
    652
    +20
    id bet a 10 meter hdmi would cost 150 quid
    i wonder when the hd boxes will fall in price
  4. bcopping
    bcopping
    May 24, 2005
    508
    28
    Brecon
    +46
    Lindy do a cheap hdmi cable which is what i am using for my projector (only £60)
    http://www.tvcables.co.uk/cgi-bin/tvcables/HDMI-10ML.html
    HDMI splitter £215
    http://www.tmfsolutions.co.uk/homecinema_Gefen_exthdmi142.htm
    Then all you would need is Magic Eye, extra Remote & 10m tvcable. probably around £30.
    probably best to ask in the cabling forums if there are any problems i havent thought of with this sort of setup though. i dont know if the splitter outputs to both simultaniously or it is switched for example (could be anoying!!)
  5. Giblets2
    Giblets2
    Jul 23, 2005
    2,277
    +183
    Why not use component over shielded CAT5? OK, you still have to watch the same channel but it bypasses the HDMI splitter as you can just use the component outputs from the existing box. Tomatoface, a forum member, has done exactly this and says it works a treat. Look in the Sticky thread at the top of this forum for more details. I'm going to attempt the same for my humble kitchen TV (HD Ready though) but I just haven't got around to it (several 'round tuits' in my size are on my wife's Christmas list!).
  6. borofoga
    borofoga
    Oct 15, 2006
    215
    +7
    Apparently you can buy the Sky HD box for £399 without any subscription.
    Does that mean you never have to pay £10 per month but also does it mean you can't watch any premium sky HD channels?
  7. Giblets2
    Giblets2
    Jul 23, 2005
    2,277
    +183
    Yep, in fact nothing but FTA - meaning BBC only for HD.
