Sky+ STB & TvLink not working
Discussion in 'Sky Digital TV Forum' started by CatSailor, Jun 30, 2005.
  1. CatSailor
    CatSailor
    Apr 8, 2005
    5
    North Crawley, Newport Pagnell
    In the recent spate of thunderstorms I have had a number of powercuts, some of which were off-on-off-on very quicky. Since then I cannot control my Sky+ box over the TVLink. It was always OK before the powercuts.
    The power led is on on all 'plug-in' remote boxes and the led in the infra red receiver pulses when you operate the remote control.
    I have plugged a tvlink directly into the back of the STB to make sure it is not the distribution amp causing a problem.
    I can go to the RF set-up menu and turn the RF power on and off and see the power led on the tvlink box go on and off in turn.
    I can do anything but operate the STB over the TVLink - The STB does control OK direct from remote control.
    Anyone got any ideas.
    Adrian Brunt
