Sky Sports Extra scrambled on multiroom
J
james616
Just got Sky+ and had the old box moved upstairs (multiroom). Subscriptions are supposed to be the same right? However Sky Sports Extra is now scrambled on the multiroom box. Anyone else experienced similar or know how to rectify the problem?
Starburst
The £10 multiroom copies the channel lineup off the first card onto the second, if you get SSX on the first you should get it on the second. It may just take a few days for every channel to become unlocked but if you are worried then either give SKY a ring or email them.
finnis
I had exactly the same problem with exactly the same channel when I first got multi-room. Sorted immediately with a phone call to Sky.
