Sky sound quality
Discussion in 'Sky Digital TV Forum' started by danny daniell, Oct 19, 2004.
  1. danny daniell
    danny daniell
    Jul 25, 2004
    1,635
    2
    +148
    Has anyone else noticed a change in sound quality from time to time or is it just me?Sometimes the sound will have a nice rich & full quality & other times it will sound weedy & insubstantial.Your thoughts please!
    Regards Dan
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +975
    On the same channel and the same program?
    It's quite possible for content from different sources to have different audio quality standards and certainly there will be differences between channels not only from the same broadcaster but those from other broadcasters.
  3. danny daniell
    danny daniell
    Jul 25, 2004
    1,635
    2
    +148
    Yes,on the same channel & on the same program.I have a very analytical Av rig which is hooked up to my Sony Digi-box via an optical lead.It is streaming Pcm data,so i should be hearing Sky sound at it`s optimum quality.I just wondered wether Sky outputs the sound at different bit-rates at different times or wether the bit rates are consistant 24/7?
    regards Dan
