Sky, Sony Rm-LP211 and learning remotes
B
Basil
I have an RM-LP211 which works just fine for all my components, I like the hard keys, and the menu system, but it has just one flaw, it won't operate my sky box (a Panasonic 1.1.U old, but good!).
As the lp211 isn't a learning remote I guess I'm stuck, unless anyone knows of either:
A way to make it work with the digibox :smashin:
or
A learning remote that has hard keys and a joystick, like the LP211, (and won't cost a vital body part):thumbsup:
Thanks in advance!
D
drdrei
I also have the RM-LP211 remote. I was holding another remote next to it and pressed the other remotes buttons and it causes the screen to flicker.
This could surely only mean that the learning "eye" on the RM-LP211 is enabled. However, this remote is not listed by Sony as being a learning model.
Is there a way that anyone knows of, which will enable the learning feature? This would be very handy for me as I have a Teac STB which I can't currently use with the RM-LP211.
Amazon Fire TV Cube Gen 3 Review: Coming Soon
