SKY+ Software Versions
Discussion in 'Sky Digital TV Forum' started by Member 7321, Oct 16, 2001.
  1. Member 7321
    Member 7321
    Mar 28, 2001
    208
    Heathrow/Warrington
    +19
    What are the latest version numbers of the software for the SKY+ box and do you update it like the normal boxes (i.e. power off, hold backup, power on) ?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    I'm running..
    OS 1.3021K
    EPG 1.20c
    I assume the same method that works on a normal digibox will work on SKY+ however I don't believe there is an update ready to go out until the end of the month.
  3. ewan hoozarmy
    ewan hoozarmy
    Mar 1, 2001
    82
    Cambridge, Cambs, UK
    +31
    As of this morning, my box is now on o/s 1.3022K and epg 1.21a
    Anyone else been updated?
    Let's hope some bugs are fixed.....
  4. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Yep same here, so much for my post last night :)
