SKY+ software update to allow second picture options
Discussion in 'Sky Digital TV Forum' started by IanW, Aug 10, 2004.
  1. IanW
    IanW
    Feb 28, 2001
    1,587
    Wiltshire
    +146
    Has anyone else had their SKY+ box updated to allow the second picture output options? This upgrade was done for non SKY+ boxes a couple of months ago. Mine has been done but does not seem to be working? :confused:
    Anyone else got this working? Did you use the 2nd RF socket?
    Ian.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    This system is only for people using the TVlink system and it does not mean SKY+ can output two different ratios at the same time, the ratio (4:3, 16:9 or 4:3 Letterbox) will be the same on all outputs.
    If you control the SKY+ from another room via the RF2 TVlink then the picture ratio automatically switches to the setting you have selected in the menu. If you control the SKY+ directly via it's main IR sensor then it selects the primary picture ratio.
  3. IanW
    IanW
    Feb 28, 2001
    1,587
    Wiltshire
    +146
    Starburst,
    Thanks for that, I think I understand what you are saying, I will give this a go tonight.
    Ian.
  4. IanW
    IanW
    Feb 28, 2001
    1,587
    Wiltshire
    +146
    Starburst,
    Doh! Thinking about it on the way home last night, and this is no good for me. :oops: My system no longer uses the sky eye, I have an IR repeating system that allows my to control any IR equipment in my AV rack from any room in the house.
    Oh well, one up side is that I told the wife she will need to replace our old 4:3 tvs with LCD widescreens. :clap: :rotfl:
    Ian.
  5. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Always a bright side:)
