Sky & Skype
Dasco777
Before signing up with Sky for broadband etc., I used a Belkin router and I was able to access Skype. However with the Sky setup I’m not able to do this. My question is: If I revert to the Belkin will I be able to use Skype or is there something in the Sky system that will not allow this?
John
Why are you not able to use Skype with SkyBB ? I have never had any issues with them
Dasco777
Thanks for your reply.
I get an error message as follows:
Skype Access is not supported
Your current WiFi network SKY**** does not support Skype Access. Please try another available public network.
Tip: Skype Access doesn’t work with private or closed networks.
Thanks - Dave
John
what are you using Skype on
EndlessWaves
No, Skype Access wouldn't be, and shouldn't have been working on your previous network either.
It sounds like the problem is that skype has started to think you're trying to use this skype access. Have a look and see if you can see a way to turn this off so you can just use skype's VoIP and not this secondary feature.
Trending threads
