Sky+ simultaneous RGB & S-video output?
Discussion in 'Sky Digital TV Forum' started by cerebros, Dec 4, 2004.
  1. cerebros
    cerebros
    Dec 27, 2002
    1,290
    48
    Leicester
    +29
    Hey all,
    Getting Sky+ next week, but will need to sort a couple more leads to properly hook into my set-up.
    What I want to know is, does Sky+ output to both the RGB SCART and S-video output simultaneously? Reason I ask is that my video is S-VHS, so anything that I want to archive I'd prefer to record at the highest quality available to me (i.e. s-video), rather than at composite (which I presume the Sky+ VCR SCART outputs). If it does output both, then I'll be able to integrate it into my set-up in the ideal way.
    thanks
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    RB from TV scart S-video from VCR scart and 4 Pin mini DIN S-video output so you can RGB to plasma S-video scart to S-VHS and S-video to PJ all at the same time.....
  3. cerebros
    cerebros
    Dec 27, 2002
    1,290
    48
    Leicester
    +29
    Cool, won't need to invest in an S-video & phono audio to SCART lead then, can just get myself another fully wired SCART :)
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    My Pace does - can't speak for the Amstrad (which is probably what you will get) :)
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    sorry yes i was reffering to PACE 3200 and 3100 units never used an Amstrad and never want to..................
  6. brackenlamb
    brackenlamb
    Oct 14, 2003
    421
    I have done this on mine,rgb scrt to tv
    svhs to dvd recorder
  7. cerebros
    cerebros
    Dec 27, 2002
    1,290
    48
    Leicester
    +29
    Ah... anyone know of anywhere I can download the manual for the Amstrad box then? I've managed to find the Pace box manual, but Amstrad don't seem so consumer friendly in this regard...
  8. philipb
    philipb
    Mar 6, 2002
    2,032
    63
    Swindon
    +148
    Can I just confirm guys - you seem to be saying the VCR SCART on the Pace V1 Box outputs s-video as well as composite? I thought it was just the latter.
  9. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    The VCR scart is composite only.
    If you want s-video then you will need to use the dedicated s-video socket.
    If for some reason that is not an option then a good quality (high cost) RGB to s-video convertor could be used.
  10. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Can't help you with the manual but there is nothing different in the spec and facilites between the two PACE models and the Amstrad. They are all built to a spec outlined by SKY and the only differences worth mentioning is when one model/version gets an OS update days/weeks earlier than another.
  11. philipb
    philipb
    Mar 6, 2002
    2,032
    63
    Swindon
    +148
    Thanks Starburst, that's what I thought. Just this from hornydragon - RB from TV scart S-video from VCR scart and 4 Pin mini DIN S-video output so you can RGB to plasma S-video scart to S-VHS and S-video to PJ all at the same time..... - had me confused.
  12. cerebros
    cerebros
    Dec 27, 2002
    1,290
    48
    Leicester
    +29
    Yeah, had me confused too (probably still am) and still pondering if i need to buy a different cable or just another SCART
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    are you sure there is no menu option for S-video from AV2(VCR)? I was sure there was
    (been a while since i played with Sky+ menu tho) PACE twin HAS and built to very similar specs
  14. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Yep I am quite sure there has never been the option to output s-video via the VCR scart, at least in retail products, can't speak for units that were part of pre-production trials etc and I haven't seen a SKY+160 in the flesh but if that could it would have been mentioned by now.
    Simply put why bother with the additional cost for s-video (scart) output when there is a dedicated s-video socket already in place.
    The TWIN wasn't built to specs and price point that was dictated by SKY though:)
