Sky+ Signal?
paul9619
I have just has SKY+ installed this morning. Now I was sat watching Sky Sports and the message "No satellite signal being recieved" was displayed. It happened for about 5 minutes. I restarted the box and removed and reinserted both coaxial cables. This fixed the problem.
However upon looking at the signal strength and quality I am getting the following.
LNB 1: Strength 50% Quality 40%
LNB 2: Stength 60% Qualtity 40%
Now I have noticed that the signal qualtiy on both is a bit erractic and is dropping on both to 10% every now and again.
Do you think its worth reporting? Is the dish not aligned properly?
SamRadford
paul9619 said:
Now I have noticed that the signal quality on both is a bit erratic and is dropping on both to 10% every now and again.
Tree branches in the signal path?
