sky signal
Discussion in 'Sky Digital TV Forum' started by jelly, Nov 30, 2003.
  1. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    on my digibox in the menu i have a signal quality and strenth in line with the " K " in the ok in the third line down is this normal also if not what can i do
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Basically only use the graphic bars as a guide since each digibox tends to display the strength/quality differently even when connected to the same dish/lnb combo.
    The question you have to ask yourself is how reliable is the picture in bad weather. A good installation (dish aligned, LNB secured, water proof connections) will give you excellent performace in all but torrential rain and heavy snow clouds so at the very worse you will only lose picture one or twice a year.
