sky signal strength / loss of sound
Discussion in 'Sky Digital TV Forum' started by kissit, Mar 9, 2003.
  1. kissit
    kissit
    just had a look at the signal strength and its showing 50% and the quality is at 25%. does the dish need moving to rectify this. also the sound keeps going off every now and again for about a second seems to be mainly on itv
  2. Fernsehman
    Fernsehman
    Sounds like a typical Grundig power supply fault. But otherwise please tell us:
    What's the make and model number of your Sky Digibox?
    What's the history of your fault?
    What have you changed that might have caused it?
    Does it show the same fault when the Digibox is connected to a friend's dish?
