SKY signal quality
Discussion in 'Sky Digital TV Forum' started by Zig, May 19, 2003.
  1. Zig
    Zig
    Since changing my digibox from a Amstrad to Grundig the signal strengh rose from 50% to 100% :smoke: however the signal quality stayed at 50% and I would like to increase this if poss.
    Is the quality linked to the cable run or the dish?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,310
    +1,217
    It might just be that the very insensitive meter in the Box is different on the two makes. A larger dish with better cable will give a better picture in most cases. The signal meter in the STB is very basic and not very accurate. For an acccuarte measure you need a sat meter that will meaure the dB signal strength.
  3. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Both... you are right in thinking it is quality that matters... on all boxes this is a good scale to go by. It is a representation of the amount of error correction a digibox needs to apply to output an image. So as a consequence, the better the "Quality" reading the better the picture. :)
