Sky signal missing on some channels
Discussion in 'Sky Digital TV Forum' started by Steve_e42, Dec 12, 2002.
  1. Steve_e42
    Steve_e42
    Hi, I am having an intermitant problem with my sony 760 sky digibox. For a few days now there are times when on some channels i get a message saying "no satelite signal received" or words to that effect, but it doesnt affect all channels, and then some time later all will be back to normal. When its going to happen, the picture freezes for a few moments, then the message pops up. Anyone had this problem before? Thanks
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Which channels?
    Programming comes from a variety of satellites from two orbital slots, identifying a common link between the dodgy channels would help to isolate a problem.
  3. cysmith16
    cysmith16
    I get the same. It's a poor connection from the sat in lead to the box. I'm going to have a look inside later to see exactly where the problem is.
    Col
  4. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    Bradford, West Yorkshire.
    +324
    Try channels 504 & 507. What do you get?
    A. Dork
  5. cysmith16
    cysmith16
    Problem is for non-subscription channels as well. Some would work some didn't. Some fiddling with the plug as it entered the sky box helped. Like, Sky one would work, but sky sports 1 wouldn't, while 2&3 would. Some movie channels worked, some didn't.
    Just rewired my f-connector, and now it works perfectly.
    Col
