Sky+ Setup with 40" Lcd! HELP!
Discussion in 'Sky Digital TV Forum' started by wright_here, Dec 28, 2006.
  1. wright_here
    wright_here
    Dec 27, 2006
    137
    +4
    Help!!
    I have Sky Plus and 40" LCD tv. The picture is ok but think it could be better! The sound is also not great from the tv so want to try and utilize the Digi Optical out on my Sky + box to get a good sound. I am also about to buy a DVD cinema system to use as well, so can use this for sound.
    This is my therory...
    I am looking to buy a PHILIPS HTS3115/05
    DVD HOME CINEMA SYSTEM so it is based on this..
    1. Connect digi optical out to DVD player so sound goes out its speakers that has II Dolby Pro Logic.
    2. Connect s-video cable from Sky+ box to DVD player.
    3. Connect DVD to TV with HDMI connection.
    Can someone help me? Will this work?
  2. andykn
    andykn
    Feb 13, 2006
    4,733
    103
    +232
    If you're currently using RGB from the Sky+ box, using S-Video from the Sky+ box will make the picture worse. If you're not using RGB from the Sky+ box, you should be.
