sky set up
Discussion in 'Sky Digital TV Forum' started by stringghost, Sep 2, 2007.
  1. stringghost
    stringghost
    Nov 5, 2006
    112
    +3
    hello
    i need to set up my sky to distribute to other rooms in the house, this is my plan can anybody tell me if this is right?
    ok got the main 2 cables coming in from my sky dish to the receiver, take a coax out of the rf2 to a booster in the loft, then from the loft to the rooms i want it in?
    if this is correct in the kitchen were the coax comes down from the loft i can plug a mini eye in the back and hey presto, but i also the tv in the kitchen has a freeview box built in do i need a seperate coax to pick the freeview up?
    thanks
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
  3. derbyjj
    derbyjj
    Feb 16, 2005
    238
    Rainhill
    +19
    what you have proposed should work fine.
    Mak sure your dist amp has IR passthrough so that the signal is returned correctly.
    Also you will only get sky from the rfout2 on teles that have an analogue tuner. so you need to check your kitchen tele.
  4. stringghost
    stringghost
    Nov 5, 2006
    112
    +3
    hi mate thanks for the reply
    the tele in my kitchen is a lcd with a built in freeview, so does that mean i will not be able to receive sky?
    also if i run a coax from a digital ariel and put in a y splitter in the back of tghe tv would i receive freeview?
    thanks again
  5. JayCee
    JayCee
    Jan 20, 2004
    23,764
    Lanarkshire
    +2,572
    If it only a digital (Freeview) tuner only...no you won't be able to tune the Sky signal in.
