Sky+ SDI mod and RGB output...
Discussion in 'Sky Digital TV Forum' started by Laura, Jul 2, 2004.
  1. Laura
    Laura
    Mar 8, 2002
    397
    Newcastle Upon Tyne
    +24
    Looking to getting a plasma with an IScan HD soon, i'd also like to get a DVD Recorder.
    I seem to remember that only the TV scart is RGB enabled, so wouldn't be able to connect the IScan and the DVD Recorder by scart simultaneously.
    I don't really want to daisy chain the Sky+ to the DVD Recorder to the I-Scan, as it would stop me watching Sky if i was using another input to the recorder.
    If i got the Sky+ box SDI modded (i have a v1 box) would i be able to use the SDI output + RGB scart simultaneously?
    laura.
  2. philipb
    philipb
    Mar 6, 2002
    2,100
    63
    Swindon
    +175
    Yes, the has
  3. philipb
    philipb
    Mar 6, 2002
    2,100
    63
    Swindon
    +175
    Yes, but this reply has to be at least 10 characters long, so yes again.
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,217
    +3,073
  5. Laura
    Laura
    Mar 8, 2002
    397
    Newcastle Upon Tyne
    +24
    Thanks Gordon, though I could have sworn i read in the manual that doing that was a no no... will dig out my manual and have a look.
    Will s-video into a DVD-R recorder be as good as RGB?
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,217
    +3,073
    Interesting question and one I can;t answer as I've not done dem.....
    S-VIDEO out of SkyPlus while scart is set to RGB will work. I am quite confident. My own Box is set to RGB and I use s-video....
    Gordon
  7. Laura
    Laura
    Mar 8, 2002
    397
    Newcastle Upon Tyne
    +24
    Ok, thanks Gordon.
